Fitting a diesel heater question
Jaywesty
Hi guys
I have a man TGE with the factory webasto engine water pre heater,
I’m looking to fit a webasto diesel heater but my concern is because I have a factory engine pre heater will this be using the spare diesel tank nipple that everybody seems to use to connect to the tank for there diesel supply..I may of dropped a clanger spacing this on my factory build?
Any advice will be super helpful i didn’t really want to drop the tank to find out the answer
Thanks in advance brilliant forum
Tee the take-off for the Air heater before the engine heater pump, I'm sure that is how it's done on the factory fitted dual heaters.
If you are fitting the Webasto in the factory position then there is a thread on here showing how I fitted an Eberspacher, they all have the same footprint so will fit the same bracket.
