Sliding door internal handle does not open the door. Is this ‘normal’
Guy
Whilst working on the van (23 crafter) I realised the sliding door internal door handle doesn’t open/unlock the door, is this normal, I assume not but there is nothing at all, no clicking, just nothing . It appears this is how it came out the factory. We are the second owners of the van, the first being the local VW dealership but I can’t see a reason to disable the internal handle. If anyone has any insight or suggestions please let me know.
Do you have a child lock activated?
Not as far as I know and also being a commercial vehicle I doubt it as this is in the cargo area, the back door handle opens from the inside. Thanks for the thought/comment though. I need to take a look inside the door skin and see if something is disconnected I think.
Well, the reason I asked is as it's a mandatory inclusion from the factory: when you order the vehicle without separator wall a child lock is fitted.
Reactions: Guy
Thanks @airhoguk ….. the answer was in the manual. It seems the prior owner has butchered the child lock switch as there is simply a gapping hole, where the switch should be. I shall have to see if I can flick the switch in daylight as I only need to do this once.
Thank you
