MAN TGE b-pillar part no's
The part numbers in the catalogues will be different but the actual parts will be the same. I bought mine from MAN and they're all VW and obviously with the VW part numbers on them as well ie 7C0......etc I'll try see what they are later. Fitting them today / tomorrow probably.
Do you have the overcab storage as well
Hi.....no..
Without taking the pillar apart.
From what I remember mine came fitted as I ordered van with bulkhead removed.
I've just (17/04/2024) picked up the MAN part number and approximate price of the left side door seal to match the B pillar trims.
656510035 -- ÂŁ46 plus VAT (I'm not happy that that is a correct part number, I think there is a digit missing)
Don't trust my info, always double check with your supplier!
FYI, these were the part numbers I used to get mine from MAN instead:
65625716019
65625716018
65625716063
65625716054
Hi, are these for the high roof please - looks like there are more parts (7) on the VW list above? Hoping to order the MAN parts as they are clearly a good deal cheaper. Also, did you change the sliding door seal and, if yes, do you have the number for that form MAN. Thanks much
Just found this forum from the FB page. I've worked out the part numbers I need, can I order online from MAN or VW?
Hi..I'm having trouble getting correct part number for right upper "B" pillar trim from MAN dealer...could you please give me list of the parts..TIA
MAN door seal part number 65626510052
Can anyone tell me the part numbers for the b-pillar trim when the bulkhead is removed? These wrap around and cover the bare metal.
I have a high roof, high cab roof trim and need the lower dark grey bit and the middle beige bit for left and right side, but not the central piece across the roof.
I have just bought some from MAN dealer..right upper trim is wrong but everything else is great
65625716019..b pillar trim
65625716018..b pillar trim
65625716109 ..b pillar trim upper
36970010002..grab handle
65625400041..Connecting piece
65625400043 .connecting piece
65625400039 bracket
65637510052..door seal
65625400042..Connecting piece
If anyone wants it the part number for the LH B pillar trim which is made for the handle( has the holes) is:
7C0867243BSY20
Cheers
Rich
65.62571.6019-B-PILLAR TRIM PALLADIUM GREY
65.62571.6018-B-PILLAR TRIM PALLADIUM GREY
65.62571.6063-B-PILLAR TRIM PEARL GREY
65.62571.6054-B-PILLAR TRIM PEARL GREY
Dit zijn Man nummers.
Hello Everyone. Joined some months ago and starting out on my Crafter conversion journey. I'm struggling to find the correct upper trims to sort the void after I removed the bulkhead. The threads and links on here have resolved the rest of my questions regarding this area of the van, grab handle, and trims / seals all ordered but the part numbers for the top trims for the standard high roof van with no upper storage seem to be missing. Sorry if I'm missing something but could someone help please. I don't have FB, so can't cross reference to that.
thanks
65625400039 bracket
did you ever get the correct top trim codes? Is the one you posted above (65625716109 ..b pillar trim upper) the one that is correct?
thanks
