I have a Crafter but have been advised that the part numbers should cross over. Not sure that is entirely accurate.MAN or VW part numbers?
Do you have the overcab storage as wellThe part numbers in the catalogues will be different but the actual parts will be the same. I bought mine from MAN and they're all VW and obviously with the VW part numbers on them as well ie 7C0......etc I'll try see what they are later. Fitting them today / tomorrow probably.
Hi, are these for the high roof please - looks like there are more parts (7) on the VW list above? Hoping to order the MAN parts as they are clearly a good deal cheaper. Also, did you change the sliding door seal and, if yes, do you have the number for that form MAN. Thanks muchFYI, these were the part numbers I used to get mine from MAN instead:
65625716019
65625716018
65625716063
65625716054
Hi..I'm having trouble getting correct part number for right upper "B" pillar trim from MAN dealer...could you please give me list of the parts..TIAJust found this forum from the FB page. I've worked out the part numbers I need, can I order online from MAN or VW?
I've just (17/04/2024) picked up the MAN part number and approximate price of the left side door seal to match the B pillar trims.
656510035 -- £46 plus VAT (I'm not happy that that is a correct part number, I think there is a digit missing)
Don't trust my info, always double check with your supplier!
MAN door seal part number 65626510052Hi, are these for the high roof please - looks like there are more parts (7) on the VW list above? Hoping to order the MAN parts as they are clearly a good deal cheaper. Also, did you change the sliding door seal and, if yes, do you have the number for that form MAN. Thanks much
I have just bought some from MAN dealer..right upper trim is wrong but everything else is greatCan anyone tell me the part numbers for the b-pillar trim when the bulkhead is removed? These wrap around and cover the bare metal.
I have a high roof, high cab roof trim and need the lower dark grey bit and the middle beige bit for left and right side, but not the central piece across the roof.
65.62571.6019-B-PILLAR TRIM PALLADIUM GREYCan anyone tell me the part numbers for the b-pillar trim when the bulkhead is removed? These wrap around and cover the bare metal.
