Hi there.
Been along to VW, and picked up the auxiliary fuel pipe which will go from the spare spigot outlet on the fuel pump housing ( on top of fuel tank).
At £13 it wasn’t expensive.it’s black hard nylon type, and overall diameter is 5mm. One end has the tank connector, and the other end is a reinforced straight bit ( which has a tube stiffener in it) which will ultimately go to inline filter then auxiliary pump to the heater.
