Victron battery to battery charger and D+ signal
Real356
Hi all I have a 2023 man tge 180 4x4 I’ve just purchased the new victron 12-12v 50amp battery to battery charger to top up my X2 190AH secondary batteries.
I have tried to run the charger with the ‘vehicle running detection mode’ and ‘smart alternator fitted ’ selected on the app but because of the smart alternator often or not the starter battery voltage drops below the 12.4 volt cut of threshold whilst driving about therefor doesn’t activate the victron charger.
I have heard of people using a D+ signal on other manufactures to bypass this flaw which from what I gather the D+ is a true signal of the engine running or not. Does this exist on the man tge? If so where can I find it? I have seen a picture on here of a fuse under passenger seat highlighted in yellow indicating it’s a d+ but a quick meter shows this is just an ignition live. Cheers Chris
It does exist, needs to be wired to the BCM and coded, the VW term is Battery Isolation in the BCM coding, that's how VW operate the simple split charge for the factory fitted second battery. I've got the factory wiring diagrams if you need them.
However most folks simply connect to an ignition controlled live in the fuse box under the left front seat via a suitable fuse. That is how I intend to do mine when I up-grade to the latest Victron 50A B2B.
Thankyou for your response, do you run a victron battery charger currently!? I have a whole bunch of questions that I need to ask as I am experience massive flaws in the system unless of course it’s something I have done / not set up correctly on the app!?
Cheers
Cheers
Cheers
Yes I do but the Victron Orion-Tr Smart 12/12 30 one which does work well without the direct wire to the ignition +12v or D+.
It's my plan to change that for the Victron Orion XS 50A soon and I expect to have to run a wire to the ignition +12v, I hope I don't have to get to the BCM to add the wire into that as it's located in a difficult place.
You may find some more help on this FB page although typically of FB you will have to sort the wheat from the chaff.
