Thought I’d share with you a switched live power supply , like say you want to put Fog lights in via a relay. I did just that , but having contacted a VW in a main town, I was told “ splice it in from another circuit
….really.?
So after a little bit of “digging” I found a spare switched live in the bank of fuses . Big blue circle is the sub bank , then the green one is the 10 amp fuse to the relay.
VW do make a factory kit, but these lights as some of you know will need programming in to the ecu
This bank of fuses is under the passenger seat.
Just thought it may help someone.
