Battery shunt removal.
S-M
Any downsides to removing the negative shunt so the starter battery is getting a good charge every time?
I replaced my starter battery with a new Bosch one a few weeks ago thinking the old one was knackered (Tayna replacement) but its still sitting at around 11.8/11.9 when i goto start it after parking for a week (ive tweeked the battery coding)
The van gives it 14v+ when coasting as normal.
@S-M as far as I am aware the battery monitor is there to ensure a 20% (ish) overhead in the battery to improve efficiency thus emissions, it also provides for some regenerative braking hence you see the voltage go up to 14v plus on the over-run and some times braking.
I can't see any good reason to remove the shunt though.
The most likely reason for your battery to seem down on volts after being parked is the same as we all have, the small but noticeable current drawn by the various modules that 'wake up' every time you open a door etc.
Many of us with leisure batteries have fitted one of the devices to keep the starter battery topped up from the leisure to solve this very problem, an Ablemail AMT12-12-5 for instance.
i use a dcds20 solar b2b setup that apparently has a starter battery maintence/trickle function although trying to find out exactly what/how it works is not going well.
I have seen functions in VCDS for "Energy management" or similar, are these related?
Can you post a link to that model?
The reason I asked is, to see if it has the function for trickle charging a starter battery.
That kind of stuff I do not touch, either a dedicated low power victron DC/DC converter or a battery master, to keep the starter battery toped up.
I'm very fussy with equipment, as I want it to be reliable, so I tend to buy top tier.
some of the websites state it has battery starter maintence once the leisure battery is charged and some dont have this information so its been hard to determine.
You will have to run some tests to see if the starter gets anything from habitation, when habitation is charged. If there is no obvious wire set up for this, nor any settings to be set for reverse charging ( by directional), my guess is, it doesn't. Even the Orion XS1400 does not have reverse charging.
But test first, then if it doesn't, I recommend van bizz battery master or Abelmail.
That's why I linked you to the manual as I couldn't see more than a vague reference to starter battery maintenance. I use an Ablemail 12-12-5 which seems to work well in the real world.
I use a victron 24/12-9 switched dc converter. My hab is 24v and starter is 12v. The feed to the DC converter is from the auxiliary pin from multiplus. A max 4A @24v converted to 12v.
The output is adjustable and set to 12.7v. The switch can be linked to a life signal to cut out when the engine runs. I just left it on for now, as starter gets to 12.7v, there is no more current flow.
After being parked all week the van is still really sluggish to start, i saw a voltage of 10.8 on my dash clocks the other day while cranking, i removed the shunt wire from the starter battery and as expected the alternator started charging constantly.
The problem with is that i now get a stop start error every single time, so i refitted the shunt wire.
The starter battery is brand new, i have since just bought a cheap solar trickle charger thats left on the dash all week plugged into the dash power socket, im told these stay live/connected 24/7
Check the trickle charger output when the sun is bright, that's mA not volts open circuit. I bet it's almost nothing.
They don't work when behind heat reflective windscreens.
i can check that although the specs stated a max of 1.2A
Ah, it may say INDIA on my tyres but it doesn't mean they came from there! Sorry, that's a very old saying, many can't remember INDIA tyres.
I'll be surprised if you get 200mA out of it through the glass.
The shunt itself doesn't enable or stop current flowing through it so I would blame it more on the smart alternator settings, however, removing the shunt will probably throw up an error code, I think you have done all you can by tweaking the battery coding.
I'm like Rod_VW and have an ablemail 12/12 (I'm sure mine is a 2A version) which keeps things good regardless of how long I sit parked up, I fitted it as my dash cam records 24/7 and if I stayed anywhere for more than 3/4 days it would throw up a 'battery low notice'
Attached is a picture of my fusebox under the single passenger seat, the Ablemail is the little unit botton middle with the red wires going to it marked '6' Onced programmed it's fit and forget.
Hi, i fixed this issue by fitting a trickle charger from the leisure battery to the starter battery, i have had no issues since 👍
