True Interior height of 4x4 standard high roof?
Tfuego
I can't get access to a TGE 4x4 to check, however from the van spec sheet I can see that the height of the rear is 1861mm.
The burning question I have is are those measurements from the metal floor to the highest metal roof panel, or are those measurements from the plywood floor to the the cross beams?
I desperately want the standard high roof 4x4 for my conversion but the internal height is borderline too low to stand up in.
I'm 5'11 and keen on insulation. I hope to be able to stand up in my van.
Thanks in advance.
I have a 4Motion and with the floor and roof fitted out (floor has 20mm XPS under the factory wooden flooring and 10mm t&g on top of that, I also battened out the roof beams so that my t&g on the roof was flat from L to R) My floor is so thick as I needed to be able to fit my shower tray and be get the cover flush to the floor (my shower is in the middle of the floor so it doesn't take up any space)
The height on my van from floor to ceiling is 1.8Mtrs or 5'11 in old money. The inside floor is jacked up by 4" on the 4Motion and RWD models to allow the propshaftt to be fitted.
If I had used 10mm XPS and not fitted t&g on top and followed the roof curve it would have been 6' Luckily I'm a height challenged at only 5'8
Pictures shows flat roof, floor and shower tray.
