Best booster battery pack?
Rich N
Hi Everyone,
I'm new to the Crafter world having graduated recently from a T6.
Just looking for some advice on suitable battery packs that will restart a vehicle battery if it should be drained.
My Crafter is a full conversion with a lithium leisure battery under the driver's seat. The second battery is therefore no longer under the bonnet. I have a 100W solar panel on the roof.
I can see the positive charge point to jump start the van but my negative earth is on the opposite side of the engine compartment.
I've looked at various options but most booster packs have short leads designed to simply attach to standard battery terminals.
Do you know of any that have longer leads that would reach both sides of the engine bay?
I don't really want the faff of dismantling the interior floor to charge a battery. I guess I can just leave it on EHU whilst not in use?
If not then normal jump leads will have to do the job.
Thanks for your advice.
As you have a lithium leisure battery and solar on the roof why not install a battery maintainer provided the van is parked in the open so that the solar can keep both charged. There are a number of devices that can do this, an Ablemail AMT12-2 is just one of them and is whet I have fitted.
Thanks very much for the advice. ATM I'm plugging in via EHU which seems to do the trick. The leisure battery has no problem maintaining charge from the solar - a big advantage of lithium over my previous AGR battery.
I'm not sure you understood what was suggested above. Abelmail or battery master, is a device that charges the starter battery from your leisure battery. Since your solar keeps the leisure toped up, this device will direct some of that charge to the starter.
Research Abelmail or battery master.
I personally use a DC-DC converter that takes power from leisure to the starter battery, and the starter battery is always at 12.75V, as long as I have some energy in the leisure battery.
