Diff locks on current Crafter 4x4
myozone
Anyone know if the current Crafter 4x4 4Motion has a central mid difflock, I know there's an option for one in the rear. I think it also uses the ABS to act as a electronic diff locks but wondered if it has a real mechanical diff lock?
No central lock, it uses a haldex system that only engaged when the front starts to lose traction.
Mine has a rear diff lock but this can only be specced at manufacture and can not be added later.
The abs is used to stop a single front wheel spinning by braking the spinning side to force power to the non spinning wheel.
Because I drive well off the beaten track I fitted a Van Der Veer haldex controller to allow me to manually control the haldex and force 50/50 split. The main issue with the van controlling it is that it's reactive. Waiting for the fronts to lose traction before dumping drive to the rear wheels just didn't cut it for me (I have been rather simplistic with my explanation)
The rear diff lock was an expensive option but it has gotten me out of a couple of places I would otherwise have struggled with.
Hope this helps.
Thanks, does the rear difflock drop out on it's own or does it stay locked if you tell it to ?
I come for a Land Rover background with positive locks, even with 3 wheels in the air it would still drive!
No it stays on till you either turn off the ignition or you hit the dash button again.
The MFD comes up with the message in the picture (or says deactivating when turning off)
The only indication after the MFD message is the yellow diff lock lights stays on when it's actually on.
Mine like the Landrover will drive with 3 wheels spinning though in that scenario I would probably be using the winch ;)
I have the rear diff lock on mine but stupidly reset its basic settings via VCDS when repairing the Haldex a few months ago.
I now have an error saying there is no basic settings, i have been unable to fix this so far, i suspect its going to require something like odis to fix.
I thought VCDS kept a log of settings changed (maybe not if you ask the module to reset) I am happy to interrogate my module and pass on what it says if that may help?
You could also ask on the Ross Tech forum for help.
the module has been reset 😅
i did find something on the rosstech forum of q similar issue and they did not have a solution.
Hope this helps.
Hi Tor, first time poster here :)
What you've explained about the Haldex controller sounds like a mod Id like to make for greenlaning in the future. Do you have a link or a part number to the Haldex controller you've used please? I've done some research online and there are a few different ones. I'd also really appreciate some guidance on fitting it if you can help. Again, I've done some research but mostly the videos are for installing the controllers in golfs for drag or track use :(
Your haldex version dictates which version you need ( I think mine is MWB) and the correct cables, if you have a diff lock you will need to tell them when you purchase as it needs another wire in the cable.
Due to a change of lifestyle I hardly use it now so it stays in passthrough 99% of the time. But it has gotten me out of some real messes.
I contacted Jeroen van der Veer and he does not have the 6th gen controller yet, these are for the Q3 2024+ builds. Waiting until he has cracked the new protected software.
The fabulous SFD new vehicles come with. Hopefully you will have it sorted soon.
i had my diff lock basic settings reprogrammed yesterday by a VW independant specialist.
The process was more involved than you would expect, the rear of the van is jacked up from the floor and both rear wheels need rotated together in sync x10 times while unlocked and then x10 timrs whils ODIS locks the diff.
