interestingly the Webasto hose is better made than the one supplied with diesel heater….no surprise there.
Being a relatively delicate item, I’ve seen these flexi tubes deteriorate over a short space of time.
So the longer one I ordered I sealed the outside of it with a type of water based sealer, then as it was going under the van , I insulated the entire tube length with a silver bubble wrap, then wound aluminium tape, which has amazing sticky properties to it, ensuring the wrap stays in place and it’s protected from not only heat but the elements, and acting as a secondary insulator.
Stainless clips to hold under van.
Not the easiest thing to route as the handbrake mechanism needed to be taken into consideration.
Then mount the exhaust with some stainless brackets I made (from flue strapping off a renovation project), and tig a smart looking 90 degree elbow.
This has all taken a long time, but I cannot emphasise enough on the longevity of securing items under vehicles!
