Cab roof insulation including the dreaded head lining removal.
rod_vw
With the author's approval here is a Facebook link to how it's done.
I made (modified) a tool for the job of removing the clips that hold the sun visors.
Screwfix no longer sell these but they do sell something very similar which could be modified to make the same thing.
Just spotted these on Temu and wondered if they would help with this job as they look very similar to the VAG ones but are only £7.98!!!
I need to do my van so might order them and let you know.
Just to give you a clue of the size that I ended up with on the above, these are very approximate.
I ground an old pair of long nose pliers but in the end I used two small screwdrivers which worked great at getting the sun visor clips out - was still a bigger of a job though!
