Anyone with a 25my Man tge help needed
Jaywesty
Morning guys
So I have a 2025 man tge and noticed a pump running under the bonnet for no apparent reason ?? open the door and it stops,close the door and it timed starts again.
The other morning i opened the van up to get some bits out and didn’t lock it 3hrs later walking past on the drive I noticed this pump running ??the other evening after being in and out of the van a few times in the daytime I noticed it running at 11pm it’s driving me nuts .
sticking my head under the bonnet the hose into the rhs metal box on the engine (egr cooler)???? Seems to be connected to said pump?
Can anyone pls check if there van does the same thing on a 2025 model?
Stupid things flattening the battery constantly,
this is ontop of the all the modules that wake up on the latest model vans when you unlock them .
I originally thought it was the tracker flattening the battery until i found this pump running for no reason
Thanks in advance hope someone else with a late van can shed some light on this problem?
I have a MY 2025 (built 11-2024) and it has something under the bonnet that's alive at times, it doesn't drain the battery as fast as yours though.
