2012 Crafter - No windscreen wipers??
TomB
Hello
I have recently bought a 2012 VW crafter and the windscreen wipers don't work, so these are the things i've checked and i'm starting to run out of ideas.
  1. Checked fuse 5 (30 amp) under the passenger dash with a multimeter and it is fine
  2. Put 12v on the wiper motor directly and it functions
  3. Pulled relay 2 and 4 from under the passenger dash fuse box and tested with 12v, the coils engage when given power.
  4. All functions on the stalk work apart from the wipers
Does anyone have any other ideas?
Help is appreciated.
Tom
Is the bonnet properly closed? Some VWs wouldn't operate the wipers with it open, mechanics fingers etc.
Hi Rod
Thank you for getting back to me, I've not considered the bonnet latch, i'm pretty sure it's been closed but it doesn't mean the switch works. i'll check if it has one and if so it's operational.
Cheers
I was able to borrow my friends VW diagnostic tool and got the following codes:
Address B4: LT3 Central Elec.
Part No SW: 9069022001 HW: 9069013100
Shop #: WSC 00000 000 00000
9 Faults Found:
9058 - Wiper Motor Change-over Relay 1 (J368) rapid operation: Short to Plus
Test Complete - Active/Stored
9070 - Front Passenger Door Central Locking System Motor (V57): Short to Plus
9055 - Wiper Motor Change-over Relay 2 (J369) on (normal operation): Short to Plus
90D0 - Roof Electronics Control Module (J528): No communication
90AB - Front windshield wipers: Blockage recognized
Test Complete - Stored
901D - License plate lights/side-marker lights: Open circuit
9004 - Programmable Special Functions Control Module (J820) : Malfunction in control module
9095 - CAN data bus: No communication
90C2 - Emergency light activated; for rotary light switch evaluation: voltage not correct
Not sure what it means by "Short to Plus" on the relays?
