G gavandi Active member Pro 29 Jan 2023 #1 Being a complete novice at off grid camping......was trying to work out what drains the leisure battery the most?
Oldrat Active member Pro 29 Jan 2023 #2 Can’t you check your control panel, using one appliance at a time ?
Pauly Active member VCDS User Admin 29 Jan 2023 #3 Anything that generates heat electrically will be a big drain along with anything mains powered running through an invertor (if you have one)
