Heads up
Ken Watt
I had an oil leak show up as an advisory on the MOT, turned out to be the crank seal and had to get new cam belt water pump etc even though it had allegedly been done less than 25k ago the w/p was leaking and the belt was so so.
If you have an oil leak get it checked unless you’re absolutely certain you know where it’s from 😉 this could’ve gone horribly wrong had I not checked it.
