Double and single swivel possible?
pabloblue
Having recently acquired a van which has been converted, I would like to fit seat swivels.
I want to keep the double as it is good for storage. So I will be taking a trip to Morecambe to get that fitted.
The single needs a handbrake solution.
I have seen three different options.
Lower the handbrake mounting, l am not keen on this as it means access is more awkward.
Replace the lever for the ratchet release type as per Grand California. These are quite pricey £300 !
Fit the Audrio tilt bracket. I prefer this, but am not sure I will have enough space to tilt sufficiently with a double seat.
Has anyone got the Audrio with a double adjacent?
Does it work?
Thanks in advance
If your van is post 2023 and needing to extend the wiring loom to the double seat swivel drop me a DM.
Thanks for the info airhoguk, looks like the best option.
Rodvw, it's a 2020 so I should be ok with the loom thanks.
That is correct, good look with your conversion. Please keep us all up to date with your build.
