Crafter 2015 Abs esp brake force distribution spinning wheel messages & non start
Timmytime
Hi New member here looking for some help !!
Since May I've had intermittent fault with Abs esp spinning wheel messages coming up , initially when they come on the dash the revs went high over 4000 rpm , was 4 hours into a journey from Oxford to perranporth , camper conversion crafter .
RAC said wheel sencor offside rear , got home OK bit of ill running ,but got home and it run OK down to Brean twice in July and to pentewan sands cornwall in August, on the way home 3 hours into the journey the messages came back on and the engine run erratically, got home OK but it was jerking alot once on the estate I live on .
Run OK for a month or so no messages and then started getting
Brake Force Distribution message and the usual ones , and non starting for several minutes , fires up messages go off and it's OK until its cold and it starts playing up again.
I had the wheel sencor replaced with the bearing unit months ago , it's only done 38k so didn't think it would be that , and it wasn't !! , messages and revs fluctuating 10 miles driving from repair .
Had 3 grey relays replaced but same issues next day when engine was cold .
It always started with just Abs esp spinning wheel after the second or third try , now with the brake force distribution message coming up it takes alot longer.
Once started it starts OK.
Before I start replacing parts as anyone else had this issue ?
No more erratic running that's stopped few months ago , just 4 messages and inspection now , that's been on the dash for years as they lad who converted the van services it every year , and he can't clear it !!
Cheers in advance for any help on this frustrating issue with me van
HI
Tried to get the van into VW main dealer for Diagnostics but waiting list was 8 weeks , local lad got the software to do it but again I'm on the waiting list .
Friend plugged it in with his Diagnostic kit , only a basic one but it would only read the engine .
I will try and attach it to this message
