crafter non runner
tezr
hello guys anyone able to give me a little advice on this. i got the van as a non runner fitted a injector and egr cooler temp sensor i coded the injector and checked the others where coded
correctly and have fitted a new battery so unsure about the system voltage not sure if it has something to do with the generator code. any help would be grate
Thursday,21,September,2023,19:04:54:05126
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WMA03VUY4L9008643 License Plate: OU20YDX
Mileage: 418524km-260058mi Repair Order: 100
Chassis Type: UY-VN54 (3Q0)
Scan: 01 03 08 09 13 15 17 19 42 44 52 5F BB BC
VIN: WMA03VUY4L9008643 Mileage: 418524km-260058miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DAUA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 SK HW: 04L 907 445 P
Component: R4 2.0l TDI H01 9790
Revision: 23203001
Coding: 001940106304010800000000000000000000000000000000
Shop #: WSC 00000 000 00019
ASAM Dataset: EV_ECM20TDI03004L906056SK 007003
ROD: EV_ECM20TDI03004L906056SK_007.rod
VCID: 08499E59B2B27B2A47B-805C
VINID: 9DD4400E696911C2400081840C81A3A3F5
1 Fault Found:
27277 - System Voltage
P0562 00 [035] - Too Low
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 417407 km
Date: 2023.09.21
Time: 04:36:41
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 15 °C
Intake air temperature: 18 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 12.406 V
Unlearning counter according OBD: 40
Air mass at air mass meter 1: 0.0 kg/h
Standardized air flow ratio: 1.000 counts
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 13.09 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
Charge air pressure: specified value: 0.004 bar
Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 972 mbar
Mean injection quantity: 30 mg/stroke
Index of current engine mode: 7
Index of next requested engine mode: 7
Index of engine target mode: 7
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 2N0 907 379 D HW: 2N0 907 379 C
Component: ESC_base H02 0860
Serial number: 08501704191209
Coding: 29AA2477483DB68A944D246412466D063DF140B8
ASAM Dataset: EV_Brake1ESP90iBOSCHVN54X 701030
ROD: EV_Brake1ESP90iBOSCHVN54X_701.rod
VCID: 372B2DA58FCCC4D2FE1-8062
1 Fault Found:
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [137] - -
[Scl_LWI_Lenkradwinkel_Error]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 93
Mileage: 418524 km
Date: 2023.09.21
Time: 04:37:01
Address 08: Auto HVAC (J65) Labels:* Redir Fail!
Part No SW: 7C0 907 184 N HW: 7C0 907 184 N
Component: Heizung H01 0401
Coding: A07110000800030001000800500101000000000000000000000000000000
Shop #: WSC 00000 000 00012
ASAM Dataset: EV_AirCondiBHTCVN54X 003020
ROD: EV_AirCondiBHTCVN54X_003_VN54.rod
VCID: 353727AD95C036C2ECD-8060
1 Fault Found:
1048838 - Functional Limitation due to Energy Management
B10CD 00 [009] - -
[Funktionseinschränkung durch Energiemanagement Ruhestrom]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 93
Mileage: 418524 km
Date: 2023.09.21
Time: 04:37:16
Voltage terminal 30: 12.5 V
CAN input signal(s) status-Transport mode: On
CAN input signal(s) status-Static current measuring mode: OFF
CAN input signal(s) status-Windshield wiper: OFF
CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 2
CAN input signal(s) status-Wipe wash: OFF
CAN input signal(s) status-Rear window heater actual value: OFF
CAN input signal(s) status-Back-up lamp: OFF
CAN input signal(s) status-Actual value of windshield heater: OFF
Blower reduction: No switch-off: no reduction
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 DE HW: 5Q0 937 084 CD
Component: BCM MQBAB B H42 0312
Serial number: 02002000400744 Dataset Number: V03935357JU 0001
Coding: 000000000000000000000000000000000000000000000000000000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020_VW26.rod
VCID: 7EA5F881E076359A7D7-802A
Steering Column Switch:
Subsystem 1 - Part No SW: 5Q1 953 521 AK HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0100121220190C401876
No fault code found.
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Dataset Number: V03935298V 0001
Coding: 2A00400100EF8448949C814D00308500000000000000000004
ASAM Dataset: EV_ACCMRRCONTIVW376 003016
ROD: EV_ACCMRRCONTIVW376_003.rod
VCID: 43D34975CB149872529-8016
2 Faults Found:
2101 - Databus
U1123 00 [009] - Received Error Message
[FAULT_ESP_STATUS_SYSTEM]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 93
Mileage: 418524 km
Date: 2023.09.21
Time: 04:38:01
Voltage terminal 15: 12.5 V
Control Module temperature: 52 °C
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.22 m/s²
Adaptive distance regulation: status: ACC_reversible_error
2055 - Databus
U1122 00 [009] - Implausible Message
[FAULT_ALP_STEERINGWHEEL_INIT]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 93
Mileage: 418524 km
Date: 2023.09.21
Time: 04:38:01
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 CL HW: 3Q0 959 655 CL
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z1PR23SA5 Dataset Number: V03935296YM 0001
Coding: 800080000000000040000000008800000065
ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
ROD: EV_AirbaVW21TS6VW48X_VN54.rod
VCID: 0A4DA451ACBE093A51F-805E
Crash sensor for front airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 454 801 010 19
Component: FrontSensor_D 305 0109
Serial number: 355002F96171A000000L
Coding: 2D2D2D
Crash sensor for front airbag: front passenger side:
Subsystem 2 - Part No SW: ----------- HW: 454 801 010 19
Component: FrontSensor_P 305 0109
Serial number: 3560002A0271A0000003
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 7LA-920-XXX-V1.clb-SRI3
Part No SW: 7C0 920 941 C HW: 7C0 920 941 C
Component: KOMBI 204 6700
Coding: 27A4110020002600018A2A010400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009069
ROD: EV_DashBoardVDDMQBAB_VW27.rod
VCID: 2615F0E158664D5A557-8072
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 442 4388
Revision: -------- Serial number: 0000443413 Dataset Number: V03935295SW 0001
Coding: 030000044F05730000000000000E00010001070000000000000000000000
GVL: 01403C0000000000400C80000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW27.rod
VCID: 70B9D6B9AA2253EAFFB-8024
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 2N0 915 181 HW: 2N0 915 181
Component: J367-BDMConti H03 1051
Serial number: 75884902001912200382
2 Faults Found:
197149 - Generator
U1052 00 [009] - No Communication
[Generator (LIN#1) Timeout]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 93
Mileage: 418524 km
Date: 2023.09.21
Time: 04:39:10
Terminal 30 power supply: 12.3 V
Terminal 15: On
8526361 - LV Energy Management
B1802 F1 [009] - Warning Triggered
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 93
Mileage: 418524 km
Date: 2023.09.21
Time: 04:39:10
Terminal 15: On
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 393 K HW: 5Q4 959 393 K
Component: TSG FS 007 0485
Serial number: 0000399455965 Dataset Number: V03935300JU 0001
Coding: 00300B200101020100001000
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHCONT_VW41.rod
VCID: 4BC36155E3445032AA9-801E
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 2N0 909 143 G HW: 2N0 909 143 C
Component: EPS_MQB_ZFLS 701 7031
Dataset Number: V03935311EH 0001
Coding: 0107
ASAM Dataset: EV_SteerAssisMNB 002009
ROD: EV_SteerAssisMNB_VN54.rod
VCID: 313F13BD61A81AE2B05-8064
1 Fault Found:
16128 - Steering Angle Sensor
B1168 F2 [047] - Not Initialized
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 93
Mileage: 418524 km
Date: 2023.09.21
Time: 04:39:51
Motor status: 00
System status: Waiting for start request
Supply voltage: 12.25 V
Temperature: 28.0 °C
KFC: 3F
KFA: 00 02
Freeze frame conditions: 5F
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 392 K HW: 5Q4 959 392 K
Component: TSG BFS 007 0485
Serial number: 0000400735444 Dataset Number: V03935300JV 0001
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: EV_DCU2PasseSideMAXHCONT_VW41.rod
VCID: 4ACD6451EC3E493A91F-801E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 7C0 035 153 HW: 7C0 035 153
Component: MU-N-T-EU 003 0025
Serial number: VWZHZ1W0011397 Dataset Number: V03935311YB 0001
Coding: 084500002800000000110001000000002F0000040000010000
ASAM Dataset: EV_MUNRUL 001002
ROD: EV_MUNRUL_VN54.rod
VCID: 5BE3911553A4C0B23A9-800E
Address BB: Door Rear Drv
Cannot be reached
Address BC: Door Rear Pass
Cannot be reached
End----------(Elapsed Time: 00:43, VBatt start/end: 12.3V/12.4V)-----------
Revision: 23203001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 417407 km
Date: 2023.09.21
Time: 04:36:41
Intake air temperature: 22 °C
Voltage terminal 30: 12.054 V
Mean injection quantity: 0 mg/stroke
Index of current engine mode: 8
Index of next requested engine mode: 8
Index of engine target mode: 8
Readiness: N/A
1 Fault Found:
U0428 00 [137] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 93
Mileage: 418524 km
Date: 2023.09.21
Time: 04:37:01
1 Fault Found:
B10CD 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 133
Mileage: 418524 km
Date: 2023.09.21
Time: 04:37:16
2 Faults Found:
2101 - Databus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 93
Mileage: 418524 km
Date: 2023.09.21
Time: 04:38:01
2055 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 93
Mileage: 418524 km
Date: 2023.09.21
Time: 04:38:01
Coding: 2D2D2D
Coding: 2D2D2D
2 Faults Found:
197149 - Generator
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 93
Mileage: 418524 km
Date: 2023.09.21
Time: 04:39:10
Terminal 15: On
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 93
Mileage: 418524 km
Date: 2023.09.21
Time: 04:39:10
Terminal 15: On
Coding: 0107
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 93
Mileage: 418524 km
Date: 2023.09.21
Time: 04:39:51
Motor status: 00
KFC: 3F
KFA: 00 02
Cannot be reached
Cannot be reached
End----------(Elapsed Time: 00:44, VBatt start/end: 12.1V/12.4V)-----------
  • Like
Reactions: mmi
For system voltage I think you need to code the battery, there is a tutorial on YouTube from Ros tech how to do it.
On t5-6 forum there’s a couple of guys that can help you with Odis and VCDS. Very knowledgeable.
thanks mate i have set the battery with vcds i have checked and repaired the lin green and yellow wire but only seeing 8.5 volts on that wire not sure if that is normal
Looks like a lot going on there and a little too much to make sense of
Firstly i would say you need to make sure your battery is fully charged, a low battery causes all sorts of weird and wonderful things
Get your laptop connected again after that and clear all the existing faults then start your troubleshooting process from there once you have ruled the battery out, if you still low voltage then you will need to start looking at whats causing it, if the voltage is ok then you can start digging into specific issues that come up on the fresh scan
all these code are fresh permanent codes that keep returning when erased even with a fully charged battery
ok, in that is the case then i suggest you ignore the steering angle sensor faults initially and concentrate on the power/connection issues
transport mode is active and it really shouldnt be so first thing would be to turn this off then do a full reset
your alternator (or some part of the charging system) has gone awol due to what looks like a LINBUS fault so this would be my first port of call
you have a couple modules for rear doors showing as not reachable so either they have lost power/data connection or should not be active in the gateway installation list ?
once you have the power issues sorted out i think the rest may well fall inline, i suspect the steering angle sensor will correct itself once the van has been started and driven
