Cables running above sliding door ???
IronDad75
Hi all, what have people done with the (rear light?) cables that run across and above the sliding door - in terms of removing from sight.
I’m looking at slatted panels for the ceiling which will sit off the cross beams and won’t be low enough to hide the cables.
One thought is to drill out the existing holes in the top corner of the cross beam, splice each cable and rejoin?
Anyone had similar conundrum and found a solutions?
TIA 🤙🏻
Yep, I did. It’s a particularly awkward place to screen of with what ever you choose to use. I ended up using some ash look polycarbonate panels and spent ages covering what cables I had there. Velcro is ok, but as I found over time due to vast temperature differences and the flexing of the van it comes unstuck!
TIA 🤙🏻
How did you resolve this in the end? I’m at that stage now. P.s can anyone see an issue with fixing ‘ceiling panels’ straight to cross beams and not putting batten on first? IMG_0660.jpeg
This is a sample piece..
I’m planning on using the slatted panels on either side of the ceiling-down the centre I’ll have a carpeted panel, the slatted panels work well because you can use them on the angled part of the beam as per your picture but the neatest solution I’ve seen for above the sliding door is to use the lightweight ply same as the furniture and build a little bridging piece, maybe with some led routered in or use it to place some switches
As for fixing to the ceiling cross members direct, I’ve seen a few different ways including vapour/thermal barriers and ply strips but not sure if this is essential?
