After much thought I decided to fit these ( filter and pump) above the ad blue tank in the recesse just forward of that. There’s a nice space, relatively easy to access.
Currently I’m knocking up a stainless steel plate with two mounting bolts on chassis, then The bolts will have rubber backing bushes behind plate, to hopefully absorb pump noise. I’ve also used quick release couplings on this before the filter and after the pump, because I know what’ll happen some years down the line!
Just waiting for some stainless hose clips , and support bracket for filter.
Beyond the pump , I plan to clip 6mm copper pipe up into the underside of heater unit .
