Alloy wheels and tyres
Im having issues running 245/65/17 on a my25 TGE specifically with intermittent right turn errors and also a few others related to radar. Man say its because of the oversized tyres as per the doc in this thread. Elite wheels who supplied the wheels say they know of issues with the new model with other sizing but 245/65/17 has never had an issue.
Someone I got hold of at Man mentioned there is a major software update that takes hours to do in the service centre that may fix the issue. Have you had any feedback from your dealer enquiry of any fix?
Cheers
Hi
I was considering this tyre set up for a 2026 crafter. Did you manage to fix it ?before i blow 2k on wheels and tyres for my overly sensitive crafter to throw a load of lights up. Thanks steve
Hi
I suggest speaking to @Lebowski , if anybody has a handle on this it will be him. Do appreciate that he is in The Netherlands though.
Actually... I have a tiny update:
The Wenning box arrived at the dealership and in a couple of weeks I'll have it integrated and I'll test.
I'm heading to Sweden for holidays so I'll have more to say when I get back.
This is very interesting ! Do I understand correctly that this Wenning box interprets the signal and can be user programmed so that larger tyres may be possible without the TPMS faults?
Yes sir you are correct. August the 21st this box will be placed in my vehicle, then I can report if all works as expected.
Technically speaking the tpms do not provide errors, it's the abs sensors that deliver a lower than expected rotation compared to the speed and this factor needs to corrected.
Now the vehicle throws yellow warnings disabling the safety systems when using the too large tyres.
Hi Broady, unfortunately not all is well, the saga continues. Wenning was closed for two weeks exactly when the box was fitted and it threw fault codes and the cruise control didn't work any more, therefore the same Friday it was removed and now we're in communication with Wenning to get a fix for this problem.
Driving with beeping fault codes is just horrible, so we took it out.
More to follow when a solution is found.
