2019 Crafter Speed limiter?
grumpyshouse
Today I discovered that my van is limited to 70mph (UK).
Would this be a factory option or an aftermarket thing? If it's a factory option can it be amended with VCDS or similar or main dealer?
Many thanks in advance
I have VCDS and don't remember seeing a speed limit option (Rod_VW, have you?)
From factory you can spect a limit at many different speeds, given this I doubt it is an after market thing. As an aside, my previous van was set to 100kph/62mph and after a while you actually do get used to it (a real pain on motorways at 62) if I could have I would of had it changed (not possible once set on the Renault Master) at least yours is a sensible 70 (actually a couple of mph less due to speedo error etc)
Check adaption channels on engine control module, if its set conventionally by VW or VCDS user its as simple as upping the number you find in the box (which may be in kmh ?)
