Still got an issue with the rear sensors.
Think it's a wiring issue. VCDS points to the Right Centre sensor. It is getting 12v on one pin and continuity to ground on another pin but I need to find the other end of the cable to be able to test the signal wire.
Is the PDC control unit under the dash to the right of the steering wheel?
When I select reverse it seems fine for 5 or 6 seconds and then throws the error. The plug to this sensor had been cut off when I bought the van but I stuck a new plug on. That seems sound.
