Hi Everbody!
I have a 2017 Crafter 2.0 177Hp, (DAVA) which I just had the EGR cooler replaced on due to disappearing coolant issue. (which is now fixed). Shortly after picking the van up from the garage the check engine light and the glow plug light came on.
Took it to a garage again and got P2080 fault codes, the mechanic reset it, but it came on again after a few minutes of driving.
P2080 - Exhaust gas temperature sensor circuit range/performance bank1 sensor 1.
I took both the sensors out from the EGR cooler, and they were both sooty, and after cleaning, sensor 2 looks ok, the other looks rusty. (pics below) Put everything back after cleaning and scrubbing the rust off. But fault code comes back after a few minutes again. I measured the resistance on the sensor, it was around 0.21 kOhm. (no idea if this is within spec, but at least it confirms the cable is intact)
Could this be just a faulty sensor, or is there anything else I should check before replacing it? Thing is I had no engine lights or fault codes before having the EGR cooler replaced, so this issue seemingly popped up after the new EGR was fitted. No other parts where replaced, except a couple of seals belonging to the EGR.
See pics:
Sensor 1 before cleaning:
Sensor 1 after cleaning - all rusty. after a bit of scrubbing I got rid of most of the rust. But I didn't take a picture of that.
Sensor 2 before cleaning:
Sensor 2 after cleaning:
Hope I can get some advice on this.
Kind regards,
Henric
See pics:
Kind regards,
Henric
