Harrywilliams
I’ve had the engine warning light show up a few times. Put it down to the fact the turbo intake pipe seal was split and the pipe was hanging off. Have temporarily glued back together the seal whilst I await a replacement and refitted. Cleared the code and then after a few drives the warning light came back with the same code. Checked the turbo intake is still fitted after the temporary fix (it was) and still having the same fault code.
Have done a few checks of the terminals on the pressure sensor and the pipes that are connected as per another forum, and it all seems in good working order?
Has anyone else had this issue or does anyone have any other ideas/can point me in the right direction as to what could be the issue?
I’m not a mechanic so if you need more information I can try my best to give it!
Thanks, Harry
Thanks, Harry
