Cable run
Ken Watt
Where are folk running their cables from starter to leisure battery? I want to put the leisure battery behind the n/s wheel arch, inside?outside? Can’t find anything online other than Greg Virgo’s Fiat running underneath and then in through the slam vent under rear light cluster..
Thanks in advance
If already converted, you may, or may not have space to run it inside, ideal. If not, running it outside its fine just use grommets/ glands on entry, and run the cable trough some coppex, to protect it from chuffing and mechanical damage. Fuse at both ends.
Everything I run is internal but I have seen people using conduit and trunking outside for all sorts of things (water/gas)
