Hi all. I'm wanting to put some kind of led light bar on the front grille area of my crafter but alil stuck to what would fit and work the best. It could be a light bar or 2-4 little pieces.
€ 15.99 - Start-Scan Car LED Hood Light Dynamic Daytime Running Light Strips Waterproof Universal 12V DRL Atmosphere Lamp 2023. Shop for cheap Car Decoration Lights online? Buy at lightinthebox.com on sale today!
Thought so!
I understand that the standard lights on the Crafter (MK2), are somewhat requiring additional lighting.
A light bar surely must be a useful addition!
Stolz präsentieren wir die Halterung, die die Verwendung von Zusatzscheinwerfer für jede Art von Auto ermöglicht, solange es Kfz-Kennzeichen hat! Beschichtung: Sprühen. Farbe schwarz. Gewicht: 0,8 kg / PC.
www.ebay.de
You find both of them from several sellers.
I fitted the mointing bracket under the plate-holder that we often use in germany.
To srew the lightbar on the tube of the mounting bracket I installed rivet nuts in it.
Because I wanted to switch it with an original button, I needed a 12 V latching relay, because the original button only give a shot signal to ground.
A little bit tricky was to have a mode, that it switch on automaticaly with the car high beam (on request). Therefore you need a canbus adapter that gives you the high beam signal. Only connecting the high beam with a relay to switch the led brings an error with the canbus.
